Adding A Washer Drain To Main Drain Stack.... - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-19-2012, 06:40 AM   #1
Rewards Points: 30
Adding a washer drain to main drain stack....
Hi Guys.....
The wife and i decided we would like to move our washer downstairs in the basement. We would like to move it to the left of the main drain stack.
The problem i am having is i am not to sure how to connect the drain & vent. I wanted to tap into existing cleanout but its a 3.5'' ABS and i can't seem to find anything that will fit.
Of course i would of readded a cleanout if it would of worked...so thats out of the question.
Then i thought of cutting the main stack but the height i would have to cut is over 18'' from the floor, cause there is the cleanout and a vent / drain that goes in the garage for a sink.
So cutting all above that to add a washer would be over 18'' from the floor and i am afraid it would be to high for the washer to drain properly ??
Maybe cut below and add some flexible couplings with band clamps or try saving the existing tube and break the existing adapter?
Any ideas.....how i can add a washer drain line ??? How would you guys do it ?
I would hate to dig up the floor as i don't want to spend big bucks.
I added a pic to give you guys a better idea of what i am up against.
Thanks in advance !
phantomvs is offline   Reply With Quote
Old 07-19-2012, 09:42 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 912
One method is to cut above the cleanout or 90 and remove wye for the sink. Then use a ram bit like this one to clean the pipe out of the existing clean out. Add a 3x2 double wye to reconnect the sink and washer.
Old 07-19-2012, 02:10 PM   #3
Rewards Points: 30
Thanks for the advice , this is sort of what i had in mind.
Do i add a double wye or a double sanitary tee ?
I guess also to reattach the 3" ABS i should use a Fernco as it probably won't give enough to glue a coupling in.
Old 07-19-2012, 06:31 PM   #4
Rewards Points: 6,652
Since we dis not want to cut up our basement floor, I just ran a ten foot piece of 1 1/2 pvc to the floor drain, then did up the P-trap and wash tub as normal. Before that, was a inch hose with a air allowance trap, connected to the old washer that came with the house.
Old 07-19-2012, 09:48 PM   #5
Rewards Points: 636
how for to the left from main stack are you planning on running pipe to wash machine? just unscrew clean out screw in a male fitting glue a 45 street then a 3 inch wye turned up. glue new clean out on the wye then continue 3" horizontal using hanger a maximum every 4' at a 1/4" per 1' fall. then depending on how far away pipe is from main stack from there on what to do. either place 3 " trap with a min. of 18 stand pipe.or a t turned reduced to 2" up to use an air admittance valve (aav) then trap with 18" stand pipe.
http://www.google.com/imgres?hl=en&s...9,r:1,s:0,i:79
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-20-2012, 06:39 AM   #6
Rewards Points: 30
The new location is about 12 feet from the main drain .
I tryed finding an adapter for the cleanout but its a 3 1/2" threaded cap. There are no adapters for that...atleast i didn't find any.
Washer Drain Hose ? calebm12 Plumbing 2 07-09-2012 09:43 PM
Horizontal Washer Drain AFTER Standpipe 3 inch?????? hammerlane Plumbing 23 11-01-2011 09:06 PM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 10:13 AM
vent fot washer drain Pabs Plumbing 2 10-11-2009 12:14 PM
washer drain is draing slow mrmordun Plumbing 13 03-08-2009 10:45 PM
