Adding A Valve W/o Shutting Down H2o - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2009, 10:37 AM   #1
Adding a valve w/o shutting down h2o
I have to cut back a cold water pipe behind the valve and I cannot get to the next valve in the line or shut down the water to the whole building. Does anyone know how I can add a valve or cap a live pipe?
dlykvn is offline   Reply With Quote
Old 02-01-2009, 11:00 AM   #2
biggles's Avatar
if your going to untread the old shutoff out of the copper fitting there just open all the cold water in your condo and flip(thread in) a new valve on and take a slight bath...the pressure will be minimal thumb on it will stop it with the others opened.if you have to swet forget it.if you want to do compression type leave the valve open looking at cut pipe first slide nut.....compression ring.....valve ...tighten it down and close the valve.
Old 02-01-2009, 12:49 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 620
Ayuh,.. Agreed...
You're going to take a Bath, no matter how you do it......
Bondo is online now   Reply With Quote
Old 02-01-2009, 11:19 PM   #4
Rewards Points: 372
Rent a freezing unit. Add that to the cost of hte job.
fireguy is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
