-   -   Adding a utility sink in the basement - draining question (http://www.diychatroom.com/f7/adding-utility-sink-basement-draining-question-69733/)
sbazzle 04-24-2010 11:26 AM
I'd love to add a utility sink in the basement next to the washer and dryer.
http://scottbazzle.squarespace.com/s...tilitysink.jpg
As you can see, however, the main cast iron drain stack is pretty high off the floor, making connecting a drain to it not very straightforward. I know I can get a pump that would take care of that, but I'm wondering if it would be OK to let the sink drain directly into the sump pit you see there, and then have the sump pump drain it out when necessary. I know the sink would be used a lot, so it's not like the water would be sitting in the pit for a long time. Any thoughts?
SuperPlumberGuy 04-24-2010 12:33 PM
It is not right and would not pass any code but, it would work as long as where ever the sump pump drains to could handle the extra volume.
Scuba_Dave 04-24-2010 01:48 PM
Yeah, doesn't meet code
Where does the sump pump water go ?
Into a drain field or...?
sbazzle 04-24-2010 05:59 PM
No, I live in town, so I have one single cast iron drain pipe for the entire house. I mean, what's the difference if I get an actual utility pump for the sink? It's all going to the same place. The sump pump never gets used (which is obviously a good thing), and the pit is right there. Ugh.
