Adding Tub Drain To Toilet Branch - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2013, 11:05 PM   #1
Adding tub drain to Toilet Branch
I am remodeling an old 2nd floor bathroom and want to put the tub on the same branch as the toilet. See the picture below.
I want to put the toilet between the tub and the tub drain. I was thinking of using a long sweep with a low heel inlet to connect the tub to the toilet and then the toilet to the stack. There is a separate vent line by the tub already, so that won’t be an issue. It is OK code in Kansas City. My question is whether this works well or not – I have read that if the toilet is not always at the end of a branch, low volume toilets tend not to get sufficient suction to pull waste all the way through the toilet’s trap. There really isn’t enough clearance to put a wye fitting between the closet bend itself and the stack Tee to connect the tub on the “dirty” side. Any thoughts?
JP's Dad is offline   Reply With Quote
toilet tub drain
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Moving my Toilet Drain and Installing a Shower Drain Hahny Plumbing 3 04-13-2011 11:22 AM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 07:51 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
