Old 09-12-2006, 01:10 PM   #1
Default Similar Question
I am adding a bath to my basement with tile on the floor. I have been told to install the toilet before placing the tile AND install tile before the toilet.....Can someone please advise which is it?
Kyle is offline   Reply With Quote
Old 09-12-2006, 02:13 PM   #2
They're all fixer-uppers
J187's Avatar
HI Kyle, welcome to the forums. Please considering starting a new thread to ask questions about your own projects, Its not really fair to the person who started this thread that we should go off on a tagent and talk about someone else's projects.
However, to answer your question, I personally would tile first, then toilet because if you decide to change the toilet later on, you are going to have a hard time doing so if you've got the existing toilet set down below the tiles. You would either have to chisel away more of the area if the new toilet was larger or build up the area for a smaller toilet. I'd just tile the whole floor and bring the closet flange up that way any toilet will fit from now on.
TRY IT, IT'S SO MUCH FUN!
J187 is offline   Reply With Quote
Old 09-12-2006, 04:25 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
I made a new thread from this post.
Ron The Plumber is offline   Reply With Quote
Old 09-12-2006, 08:52 PM   #4
My apology for not knowing the rules. I just stumbled on this site today - it is great! Thanks for the quick reply.
Old 09-12-2006, 09:44 PM   #5
Journeyman Plumber
Like J187 said, tile 1st, then set toilet, also raise the flange if you can to proper height on floor, top should be 1/4" above the tile surface.
Old 09-13-2006, 10:51 PM   #6
Hey Ron,
If you tile the floor first , should you then just install the flange over the tile.
TonyD
TonyD is offline   Reply With Quote
Old 09-13-2006, 10:59 PM   #7
Journeyman Plumber
We will set the flange to proper height off the subfoor by adding spacer for desired height, then floor is tiled around the flange, when floor is finished, flange is ready to receive the toilet.
More On This Topic
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
All right, so we notice that the wax ring is a little low on this side, so when we reset the toilet we're going to keep an eye out to make sure that that has the proper amount of wax on there. We want to remove all the excess wax; make sure we don't get... Read More »
I showed the toilet cut; that is where you are coming around the flange of the toilet. What we showed here was that you could kind of rough it in. Maybe you cut a few pieces in with the larger saw and then with the grinder fitted with the dry blade and... Read More »
My name is Jeff Pence and I am with Bob Street today from Houdini Home Improvement in Lebanon, Ohio on behalf of Expert Village. In this clip, we will be installing the toilet bowl under the wax ring onto the sewer pipe. First we will carry it in... Read More »
Removing a Toilet
Removing a Toilet by Expert Village
Now, before we pull a toilet, we've emptied the tank for the water. That was easy, but we need to empty the bowl of the water. So what we'll do is we'll pour a bucket of water; half a bucket of water in the toilet, and we'll pull it kind of fast, and the... Read More »
Toilet jpark Plumbing 18 01-05-2009 09:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 09:55 AM
Tile on basement floor Sarge Flooring 12 07-05-2007 09:41 PM
toilet install over new tile floor dbrew Plumbing 6 02-21-2007 01:17 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 07:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
