Adding A Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2011, 08:15 AM   #1
PA PE
Adding a tankless water heater
I have recenly, within the last year, installed a new 50 gas water heater, but I am still having a problem with the amount of hot water reaching the 2nd floor shower. I was wondering if I can install an on demand tankless water heater at the shower location. Will this help? Should I put it on the hot water line or the cold water line? How can I determine the flow rate at my shower? Is the flow rate measured with both hot and cold on or just the hot?
schultz56 is offline   Reply With Quote
Old 01-19-2011, 10:06 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... I'd sooner think you have a problem with the shower Faucet, 'n adding yet another water heater won't help a thing....
Old 01-19-2011, 10:18 AM   #3
HVAC Contractor
Have you tried a recirculating pump installed under the sink for that bath? I have had good success using those in my home.
1acman is offline   Reply With Quote
Old 01-19-2011, 10:29 AM   #4
PA PE
What is a recirculating pump?
Old 01-19-2011, 11:36 AM   #5
HVAC Contractor
A recirculating pump will keep hot water in the lines so you do not waste water when you turn the hot water on. Check out your local Home depot or lowes, they will have one in the plumbing section. Have you tried turning the thermostat up on your water heater?
Old 01-19-2011, 11:49 AM   #6
What is the size of the water supply pipe, both hot and cold going up to the bathroom?
Navien Plumber is offline   Reply With Quote
Old 01-19-2011, 12:18 PM   #7
PA PE
1/2" copper. Yes I have turned up tstat on tank.
Old 01-19-2011, 12:44 PM   #8
Bondo's Avatar
Ayuh,... Do you have good hot water else where in the house,..??
Do you have good hot water in other faucets in the same bathroom as this shower,..??
Old 01-19-2011, 01:05 PM   #9
PA PE
yes good hot water everywhere, just doessnt seem to last long. I only seem to run short during/after a shower.
Old 01-19-2011, 01:08 PM   #10
PA PE
I also have a shower in the basement, (the man shower), seem to have plenty of hot water when showering down there. Which makes me think that the problem is either the distance from the tank to the upstairs shower or onthe way to the second floor the hot water pipe must pass through a cold air zone somewhere. Either way I thought the solution would be to add a point of use tankless water heater at the upstairs shower. Just not sure how to do it.
Old 01-19-2011, 01:24 PM   #11
rditz's Avatar
if you are running out of hot water after or during 1 shower, are you sure that both elements are working (assuming an electric water heater)?? did you turn both of them up?? what are they set to?
rod
rditz is offline   Reply With Quote
Old 01-19-2011, 01:34 PM   #12
Experienced
Jackofall1's Avatar
If you can, before installing a tankless, POU, unit for your shower, insulate as much of the HW line as possible, I found that once I did this, even though I couldn't get in the walls, just the basement line was enough to make a big difference in longevity.
Old 01-19-2011, 05:11 PM   #13
PA PE
It is a gas tank, and I already have insulated the lines in the basement. I could try putting one of those blankets on the tank itself. But I think I am at the point of requiring a pou tankless for the shower. I wonder if I could hook it up the hot water line. All info I have seen shows connecting to the cold supply.
Old 01-20-2011, 08:05 PM   #14
Send a message via MSN to terrylueders
I do not think you understand your problem yet. You do not want to fix it until you understand it. And, I think it could be the shower valve upstairs. If you can take a shower downstairs, you can take one upstairs. Its that simple if you have the same showerheads. If the flowrate of the showerhead upstairs is triple that of the one downstairs, that could be a problem. Switch showerhead and see if the problem moves.
Good Luck!
terrylueders is offline   Reply With Quote
Old 01-20-2011, 09:19 PM   #15
I agree with what Terry said!
broox is offline   Reply With Quote
**I just installed my RHEEM ECO-SENSE 180DVN3 tankless water heater 57_Hemi Plumbing 21 01-03-2013 11:32 AM
Location for new Tankless water heater? bb_sam Plumbing 9 03-09-2010 09:09 AM
Tankless Water Heater Problem Thalweg Plumbing 4 12-10-2009 12:18 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 08:49 AM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 10:41 PM
