-   -   Adding spigot with a quick tap (http://www.diychatroom.com/f7/adding-spigot-quick-tap-70353/)
Shrute 05-02-2010 10:41 AM
You know how they have that little quick connect tap thingie for refrigerator ice makers? Do they make something like that for a little spigot?
I just need a low pressure spigot to get a little bit of water from occasionally. I want to tap into a 3/4" line that I can't shutoff. I know this isn't the optimal way, but it will work perfectly for me.
downunder 05-03-2010 06:44 PM
There are larger taps like what you referred to for refrigerators. Not a spigot exactly, but if you just want to have access to the water, you might could use a water supply cutoff like for supply line at sink, toilet, etc. on a larger tap.
Alan 05-03-2010 09:28 PM
Those saddle valves that they sell are pretty neat for something with a very low flow rate.....
That being said we do not use them. What we have learned about copper piping is that turbulence in the water DESTROYS IT. What happens when you make a hole in it with a drill bit? You're creating a huge dent/burr on the inside of the pipe which is going to cause turbulence.
No good at soldering?
If you need a plumber, save yourself a little $$$ by making the cut where you want the tee and draining the lines out yourself. That much time less that he is sitting around waiting for it to drain before he can solder.
OR you can try slapping in a sharkbite tee.... not optimal in a copper system, but they work great for mobile home repairs.
downunder 05-04-2010 06:18 PM
I must have missed where the pipe was identified as copper. Maybe it is PVC/CPVC. Our local water dept used one on a three inch line as the supply for our shop.
Snav 05-04-2010 06:38 PM
Shrute - I installed a regular spigot off of our main water line without much drama.
We have cpvc under the house - so I used a Tee to branch off, drilled a hole in the brick, strung through a copper nipple, and attached the plumbing and spigot - caulked it in place - tada.
Took me about an hour or so but it's fully functional and I have no qualms with my work seeing as how I didn't cut corners or try to get it done faster.
tpolk 05-04-2010 06:41 PM
i have no idea where the op is trying to get to as a finished product. little help here shrute
Shrute 05-04-2010 10:48 PM
Yes, it's 3/4" copper. The end result doesn't really matter, I just need a little a way to tap the line without shutting it down, like you would for a fridge hookup.
Alan 05-05-2010 09:12 AM
I am pretty sure those mini saddle valves you buy at the hardware store aren't approved for use on plastic piping, is why the assumption was made. :wink:
Besides, if it was plastic, how hard would it be to cut in a tee? :huh:
Alan 05-05-2010 09:14 AM
Why can't you shut it down?
Those saddles for refrigerator lines are only 1/4" I'm not sure what sizes you can get, but you definitely want a 1/2" one at least.
Shrute 05-05-2010 05:46 PM
Because it is completely unnecessary to schedule a shutdown and drain hundreds of feet of water lines and do the work involved with sweating in a new fitting for the trickle of water that I need.
Any plumbers here have a solution to the original post?
downunder 05-06-2010 07:01 PM
Here's one item to consider:
14. Saddle Valve (our Catalog # Saddle-Kit) – see photo – saddle valve with bracket and piercing mechanism to clamp into cold water pipe up to one-inch diameter (PVC, copper and brass pipes only, not for braided hose; for iron pipe, you need to drill a hole); built-in connector of High Pressure Hose screws onto this Saddle Valve (no adapter needed); MUST order High Pressure Hose with this item – $13
http://www.greensmoothie.com/pic-water.html
Took me about 90 seconds to Google this on "3/4 inch saddle valve." This is for an irrigation system but I presume that the water line doesn't care what it supplies.
Should I spend five minutes more finding others?
downunder 05-06-2010 07:16 PM
I might as well. Here's three others that I found with a brief application copied.
Blazing Saddle™
The Leader in Self-Tapping Fittings.
"Save time and fittings with the leader in Self-Tapping Fittings."
-- Landscape Contractor Magazine (Product Focus; May 2002).
  • 10 SECONDS to tap polyethylene or PVC pipe
  • EASIEST way to install a sprinkler head
  • SHAVE HOURS off your installation
For PVC
BS 5PVC 3/4" x 1/2" FPT
BS 6PVC 3/4" x 3/4" FPT
BS 7PVC 1" x 1/2" FPT
BS 8PVC 1" x 3/4" FPT
Product Information
For installing automatic ice maker kits on refrigerators. Kit includes angle needle valve designed to control accurate water flow into evaporative cooler units, plus a saddle clamp that permits installation in water pipe nearest humidifier unit. Furnished complete with copper tube insert and gasket. Cadmium plated clamps and bolts. Saddle clamp made to fit 3/8 inch , 1/2 inch and 3/4 inch .
Other products by Anderson Metal or in Needle Valves
  • <LI class=copyHeading>Nonself-Piercing
  • Installed on 1/2 or 3/4" galvanized water pipe by drilling 1/4" hole in pipe, installing pilot tube, and tightening.
Shrute 05-06-2010 08:24 PM
Wow, you're almost as smug as tpolk.
I was looking for the entire system, a simple way to interconnect a spigot with the tap.
Alan 05-06-2010 09:30 PM
So then shut it down, and use a sharkbite so you don't have to drain all the lines to sweat a fitting? Sharkbite will take you 2-3 minutes, put a valve on the Tee branch, shut it off, turn water back on, continue working on your project.
Or use the saddle. Just get ready to shut down the water and drain all the lines to make repairs due to turbulence in the lines. :whistling2:
