Adding A Showerhead To A Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2010, 01:01 PM   #1
Adding a showerhead to a tub
Hello
I am considering renting a flat, but it has only a tub and no shower in it. The estate agent told me i could "easily find an adaptater that link the two taps of the tub to a shower head" that I would then have to fix on the wall. However, my poor english not helping, i really don't know first, if that sort of stuff really exist?? and second, if it does, what is the name for it?
I am not a diy expert so i do not want to destroy the walls, remove the tub, change the whole tap thingy and pipes...
moneypenny is offline   Reply With Quote
Old 01-06-2010, 05:00 PM   #2
Adding a shower head to a tub
I do not know where UK is but the landlord is supposed to do that.
There should be an opening in the center of the tub fawcet which
allows you to extend a pipe to a regular height where you can install
the shower head. I do not know if the fawcet has a diverter.You have
to break the wall in order to install the pipe.
Gabriel24 is offline   Reply With Quote
Old 01-07-2010, 11:18 AM   #3
Rewards Points: 150
you can buy a tub spout with a shower hose diverter.ad a personnel shower head with flexible hose and attach shower head holder to tub wall.
rudolph58 is offline   Reply With Quote
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Adding add'l support for beam WaldenL Building & Construction 3 09-01-2009 09:00 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 10:51 AM
