Old 06-25-2012, 10:56 AM   #1
adding a shower over an existing concrete/tile floor.
I'm putting in a shower in a room with a concrete and tile floor.The shower will be next to an outer wall and 6 feet away from the drain going from the house to the sewer line. I want to keep from busting up the floor if possible. IDEAS??-Jay
birdman1 is offline   Reply With Quote
Old 06-25-2012, 11:14 AM   #2
Unless it's built on a platform, it's not going to happen.
Far better to bit the bullit and cut out the floor. Your going to need room for a trap under the drain also.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Adding a floor over a floor with insulation in between. ThoughtIKnew Remodeling 12 04-19-2012 11:51 PM
Basement Concrete As Shower Floor? rmontyw Plumbing 4 03-08-2012 12:07 PM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 06:15 PM
Adding Pergo to Existing floor jtyates533 Flooring 7 01-11-2007 02:55 PM
