Old 10-14-2011, 12:26 AM   #1
adding shower - drain problem
Hi there-
I want to add a shower in my condo. I want to keep the bath top. To add another drain is almost impossible because of amount of work and cost.
A contractor friend told me about a shower pan that has a pump included so it can be connected to the drain of the sink in the bathroom.
I cannot find any info about this anywhere. Does this exist? Where can I find information about it.
thank you.
Anton
glanzinc is offline   Reply With Quote
Old 10-14-2011, 07:28 AM   #2
I think he is talking about a graywater pump, commonly used in basement where the drain lines are located above a sink. I suppose it could be used where you want, but it does not sound any easier to mount and plumb the pump as to run a new drain line. Plus, you need power for the pump.
Old 10-14-2011, 10:14 AM   #3
Doing it myself
Alan's Avatar
I agree. If there is a drain nearby you're going to have to go that route. I'm pretty sure an inspector isn't going to let you put in a pump when there is access to a gravity drain. The pump is more expensive and bound to fail eventually, and more likely when you are in the middle of showering.
Journeyman Plumber
Alan is online now   Reply With Quote
Old 10-15-2011, 01:35 AM   #4
Persona Non Grata
VIPlumber's Avatar
Your friend was probably talking about a Saniflo system. But like JBill and Alan mentioned it'll have to be hooked into a drain which won't make it any easier or cheaper.
VIPlumber is offline   Reply With Quote
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Centering existing drain to shower insert? Squeakyhinge Plumbing 5 04-07-2011 08:27 AM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 08:51 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 11:06 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
