Adding A Shower Drain In A Cement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 09:07 PM   #1
Adding a shower drain in a cement floor
I am in the works of installing a new shower and have a few questions--
I most likely will be moving the floor drain from were the tub used to be and do i need to vent that line or would it already be vented. There is also a drain from the sink upstairs that runs into the floor as well. I know this will require cutting up the floor and not a biggy.
So which one should i use, and how should the pipes be run. I am not afraid to do any of this job so bring it on Guys!!! Look at the attached picture for explanation. If you want to draw this out go for it.
Thanks to all in advance
robsutton is offline   Reply With Quote
Old 01-27-2012, 09:14 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by robsutton View Post
I most likely will be moving the floor drain from were the tub used to be...
How far?
...do i need to vent that line or would it already be vented.
has it been draining OK?
Can't see enough from here to say.
Old 01-27-2012, 09:16 PM   #3
Rewards Points: 13,690
No pictures were posted.
Old 01-27-2012, 09:30 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
I would bust out the floor drain and connect to it for the new tub drain. If it is a tub/shower you need 1 1/2" pipe and if it is a shower only it needs to be 2"
It should already be vented because I would assume that it ties into the drain line coming down from the sink upstairs
Also, the way the pipe is connected into the floor drain and being used for the tub removed isn't good. Even though the trap of the floor drain was being used for the tub. I have seen this connection like this come loose and cause major problems.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
robsutton (01-27-2012)
Old 01-27-2012, 10:00 PM   #5
I plan on cutting that pipe off below ground and capping it. Would i just cut into the pipe below were i want a drain and tie it into that line below ground?
Old 01-27-2012, 10:07 PM   #6
Rewards Points: 560
I would bust out concrete and see where the floor drain goes. You may be lucky enough that it lines up somewhat to what you need for the new tub. Then cut off the floor drain and use a fernco to tie on and run pvc for the tub.
Old 01-27-2012, 10:15 PM   #7
Its hard to tell from your picture but some of your studs look like they are directly on concrete. You are not suppose to put studs, or even plywood, directly on concrete like that unless they are approved for exterior use or there is a vapor barrier inbetween.
jasin is offline   Reply With Quote
Old 01-28-2012, 12:54 AM   #8
that was the last owners work. It still all needs to be redone. Though thanks for noticing
Old 01-28-2012, 03:22 PM   #9
so here is were it is today. My question is not sure which direction to run the p trap. As you see the 2 blue arrows, if you were to intersect them, they would just about be over top of the main line i need to tie into. So, how would i run the trap so that it came back over top of that line so it is done CORRECT.
Old 01-28-2012, 04:29 PM   #10
Rewards Points: 560
Cut the pipe close to the hub off the 90 where it comes through the concrete. Place a Y and off the Y put the trap. You should be able to angle the trap back far enough so that as the trap comes up you can 90 it to the tub.
robsutton (01-28-2012)
Old 01-28-2012, 08:32 PM   #11
The Following User Says Thank You to jasin For This Useful Post:
Plumber101 (01-28-2012)
Can you use a floor drain for a toilet? tibberous Plumbing 6 09-20-2011 08:43 AM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Help with shower drain install in concrete floor!! psychomti Plumbing 0 05-17-2010 01:54 PM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 08:06 AM
