Old 06-02-2011, 06:16 PM   #1
Adding a shower in basement with in-floor heating
Hello all,
I have an unfinished basement that has radiant in-floor heating. I want to add a bathroom down there and there is a roughed in toilet drain and a sink drain I can hook into. How can I add a shower as well? Is there a shower that can sit above the slab that does not require breaking up the slab. I am reluctant to break up the slab to add drains because of the tubing in the floor.
Any suggestions?
Thanks,
Eric
ejanzen is offline   Reply With Quote
Old 06-02-2011, 08:37 PM   #2
There are companies like Saniflo and Liberty pumps, that make toilets that are designed for basement or below grade installations that allow for the installation of two other fixtures connected to the toilet pump, or you can get a self contained pump assembly and tie that into the roughed in toilet drain (mainline drain) Look at liberty and zoeller websites.
NickFixit is offline   Reply With Quote
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 01:16 PM
How do you install a walk-in shower in a basement with floating walls? ronquillor Tiling, ceramics, marble 1 02-20-2010 05:57 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Basement shower install howto greight Building & Construction 4 04-13-2009 05:19 AM
