Adding Shower Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-08-2010, 12:16 PM   #1
adding shower base
I have a pre fabricated shower base - made from a composite. It's very solid, so flex or bounce is not an issue. The edges are on level with the bottom (that's to say if I put down more concrete it will raise the edges of the shower base above the finished slab. My questions are these. 1) This shower base probably weighs about 125lbs. Do I need to put any adhesive on the bottom to adhere to the slab or is the weight good enough due to the fact I will later tile around the edges? 2) The shower base has a flange edge that is about 1' high and a 1/4 inch thick. I know typically you drop the backerboard or greenboard in front of this flange. The problem is this creates a 1/4 inch gap between the board and the framing. Do I put green backerboard on top of the flange and than drop backerboard down they way it should be? Probably not very clear on this. I've included a picture of the flange. It's resting against a wall and this flange runs around 3 sides. It's a left side drain.
kerbongi is offline   Reply With Quote
Old 08-08-2010, 04:33 PM   #2
DIY staff
Rewards Points: 7,174
That base can be installed with a thin layer of thinset--Just like setting a 125 pound tile.
The 1/2 inch backer board ,for the wall ,rests on top of that flange---not in front of it.
Fill the gap with thinset as you tile---If you are water proofing the backer board with a liquid paint on membrane--then you will fill that gap with thinset before you paint on the water proofing.--Mike--
Old 08-08-2010, 09:07 PM   #3
Mike,
Thanks for the reply, I appreciate your time. Can you elaborate on a few things I was unaware of....? Should I put on the liquid paint on membrane in your opinion? What is 125 pound tile? Sorry, no real knowledge of plumbing or tile work as of yet. Thanks for your time, I sincerely appreciate it. Tom
Adding a shower head ideas Pontiacgirl Plumbing 1 01-23-2010 07:56 PM
Shower Base smithjnj Plumbing 3 11-28-2009 09:06 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to build base for a shower stall atm Plumbing 13 05-13-2009 10:18 AM
Basement shower install howto greight Building & Construction 4 04-13-2009 04:19 AM
