Adding Show To Existing Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2009, 12:28 AM   #1
adding show to existing tub
i am a new home owner and we have a bathtub in our downstairs bathroom. we would like to make it a shower as well but don't want to tear through walls to do so. is there a way to do this. also the bath is a very odd tub - the water spout is build into the middle of it and just falls straight down. any ideas would be great.
thank you
kristina3681 is offline   Reply With Quote
Old 09-24-2009, 09:42 AM   #2
Only one of those rubber hoses that slips onto the spout. To add a shower, you need to connect piping into the water supply valve in the wall. Then add a shower head.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-24-2009, 12:00 PM   #3
thank you
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 11:32 PM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 06:15 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
Adding a room, tie in to existing framing rampeyboy Building & Construction 4 12-26-2008 04:16 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
