Adding A Second Toilet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2010, 10:31 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Obviously this configuration creates issues if you only have a 3" line coming into the building. There are other ways to do it, but I can't tell by your picture how much raw pipe you have to tap into. This would be the least amount of pipe and fittings.
Here's your fixture cross : http://www.terrylove.com/images/abs/...ture_cross.jpg
I'm just assuming that they make that in a 4x3x3x3 config....
Journeyman Plumber
Old 06-30-2010, 07:20 AM   #17
the Musigician
DangerMouse's Avatar
What is a san-cross?
Here's a pic of one way I think I can do it.
The other sink and tub vents could be attached to the new vent stack, yes?
Alan: Your drawing would require me moving the existing toilet. This would be hard to do.
Thanks guys!
DM
Old 06-30-2010, 09:08 AM   #18
the Musigician
Originally Posted by oh'mike View Post
I've been in the attic of a mobile.....
You're kidding me, right?
If not, my daughter has this friend that wants to meet you if you're single!
DM
Old 06-30-2010, 10:02 AM   #19
Doing it myself
Alan's Avatar
Thanks guys!
DM
The only thing that worries me about this setup is that without a proper vent between the tee for your new toilet, and the old toilet, that your old toilet may be subjected to some siphoning as the new toilet is flushed.
You wouldn't have to 'MOVE' the old toilet, just re-plumb it. If you're under there anyway... eh....
A san cross is the same type of fitting, except the inlets have short sweeps. You don't want that for toilets.
Journeyman Plumber
Old 06-30-2010, 10:45 AM   #20
the Musigician
How about this to fix the siphon effect?
DM
Old 06-30-2010, 10:53 AM   #21
the Musigician
But it'd probably have to be a 3" at least, right?
DM
Old 06-30-2010, 07:03 PM   #22
DIY staff
Rewards Points: 7,174
DM--3" is fine for the vent size.
I am very thin--however,not that thin----
Old 06-30-2010, 09:50 PM   #23
Doing it myself
Alan's Avatar
While that wouldn't fly here, I'd be willing to bet that you won't have problems with it. I'd prefer to use a wye/45 or a combo fitting on the toilet discharge side to eliminate the possibility of solids getting stuck in a santee. 3" will be great for the vent.
Journeyman Plumber
Old 06-30-2010, 09:57 PM   #24
the Musigician
wye/45 or a combo fitting? santee?
pictures?
DM
Old 06-30-2010, 10:03 PM   #25
Doing it myself
Alan's Avatar
Sanitary tee : http://images.orgill.com/200x200/2221158.jpg
Use this on your vent side to connect the vent coming from the old toilet to the vent stack
Found the perfect picture to differentiate....
http://media.photobucket.com/image/A...mbing/tees.jpg
Hope that makes sense :D
Here's a picture of a combo by itself
http://images.orgill.com/200x200/5851548.jpg
I think a wye + 1\8 bend is self explanitory, but for simplicity's sake when measuring, i'd just use the combo.
Journeyman Plumber
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
adding shower and moving toilet firehead67 Plumbing 1 08-15-2009 07:52 AM
Question about Adding toilet to basement dasaint80 Plumbing 5 05-05-2009 08:27 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
