Adding A Second Toilet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-25-2010, 10:39 AM   #1
the Musigician
DangerMouse's Avatar
Adding a second toilet.
The wife wants a second toilet, so I'm adding a small half-bath as I finish up my new framing. This is what I intend to do underneath. Is it ok?
Is the 2" vent pipe through the roof OK? Or do I need to put in different?
Just double-checking to be sure I'm good to go, Po)
Thanks!
DM
Old 06-28-2010, 07:29 AM   #2
the Musigician
no-one?
anyone?
DM
Old 06-28-2010, 07:35 AM   #3
DIY staff
Rewards Points: 7,174
What is the distance to the new toilet? Looks fine to me --but a vent for that might be required.
Old 06-28-2010, 07:39 AM   #4
the Musigician
3 feet-ish... the old vent is attached to the kitchen/bath sink 2" drainpipe.
DM
Old 06-29-2010, 12:25 PM   #5
DIY staff
Three feet? You are fine---go ahead with the rest of your planning.---Mike---
Old 06-29-2010, 12:28 PM   #6
the Musigician
So the 2" vent (utilizing the 2" drain shown) is OK to go through the roof?
It was fine when it was a mobile, but it's a house now.....
DM
Old 06-29-2010, 12:30 PM   #7
the Musigician
The toilets will be back to back with a wall in-between, so whatever that distance is...
they'll share water source through wall.
DM
Old 06-29-2010, 07:30 PM   #8
DIY staff
I think you are O.K.--I will feel better when Alan or one of the other plumbers chimes in.--Mike--
Old 06-29-2010, 07:51 PM   #9
the Musigician
I hope soon, I'll be pulling the permit shortly and doing it.
Rather not have to pull it apart and redo it!
DM
Old 06-29-2010, 08:24 PM   #10
DIY staff
My biggest concern is the vent---I know the 'shared' vent drain will work--However I am not sure if the code will allow it in a house.--Mobile homes get away with a lot.
I didn't realize that that part of your home started life as a mobile. I assumed the original had met code.
That's my fault for assuming something.
---Alan---Wake up,Alan----
Old 06-29-2010, 08:35 PM   #11
the Musigician
My concerns exactly....
DM
Old 06-29-2010, 09:01 PM   #12
DIY staff
How big a deal would it be to punch a new proper vent through the roof? Will you be opening the ceiling?
How old are the shingles?
I've been in the attic of a mobile and I believe opening the ceiling to route the new vent would be easier than crawling around up there. You have a vent fan to go in also?
Old 06-29-2010, 09:53 PM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Depends on where you're at I guess. One thing i've learned on this site is how grossly different plumbing design and theory is from state to state. Seriously, are the laws of physics different in these places?
First off, that "vent" is not legal by Oregon code. That would be classified as a drain, and the kitchen, bathroom lavatory and tub would each have their own vents (not necessarily each one through the roof, but probably tied together in some manner in the attic or walls as possible)
The same goes for toilets, HOWEVER, when you're using a double fixture fitting (fixture cross), the 'outlet' or bottom of the fitting needs to be one pipe size larger than the inlets, meaning you'd need a 4" line going into the bottom of it, two horizontal 3" lines hitting the closet flanges, and 3" vent through the roof. (two toilets is an automatic 3" vent here) 4x3x3x3 fixture cross (not a san-cross)
Journeyman Plumber
Old 06-29-2010, 10:12 PM   #14
the Musigician
Ummmm, can you draw me a picture? LOL
I will be adding a new hole in the roof, but I only want to make ONE hole, so I need to design this right.
Thanks guys!
DM
Old 06-29-2010, 10:21 PM   #15
DIY staff
I knew Alan would shed some light on this--Thanks Alan.---M---
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
adding shower and moving toilet firehead67 Plumbing 1 08-15-2009 07:52 AM
Question about Adding toilet to basement dasaint80 Plumbing 5 05-05-2009 08:27 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 09:59 PM
