-   -   Adding a Second Sink to Vanity (http://www.diychatroom.com/f7/adding-second-sink-vanity-153893/)
MartyB 08-16-2012 12:53 PM
Hello,
I am currently renovating our master bathroom and have ordered larger vanity cabinets and am thinking of adding a second sink.
The vanity is 75" in length (30" vanity is 21" deep; 15" drawer bank that is 18" deep; then another 30" vanity).
Currently there is a 2" waste line that comes up under what would be the left sink and a 1.5" vent that I will tie back into that goes into the wall. Given the length of the vanity, the drains would be 45" apart and I would use the space behind the drawer bank to run the drain lines through.
Should I just come off the 2" line with a double santee and convert everything from that point to 1.5", with one drain running the longer distance to the right sink (~45") and the other being a short distance to catch the left sink? Then there would be 2 traps installed. I would then have the single vent off the double santee to reconnect with my 1.5" pipe that currently exists.
Thanks in advance,
Marty
DannyT 08-16-2012 01:37 PM
that should work fine. that is the way i used to do the piping in the walls for a double vanity.
MartyB 08-16-2012 08:45 PM
Thanks Danny. I wasn't sure if i needed to separate the drain/vent for each sink by using a couple Wye's.
joecaption 08-16-2012 11:39 PM
Nope, one drain one vent.
Look under you kitchen sink of you have a double sink.
TheEplumber 08-17-2012 12:33 AM
199 Attachment(s)
Yep, nothing wrong with 2 lav traps sharing a vent
But instead of a double san tee- I use a fixture cross. It helps direct a drain snake downward rather then straight across the tee. Just a thought...
