Old 06-03-2011, 09:43 PM   #1
Adding a second sink to existing drain/vent
I am adding a "party sink" or wet bar sink to my rec room and I want to know the right/best way to add the drain. The new sink will be on the other side of the wall from the existing bathroom sink drain/vent. Can I just connect into the existing PVC line with an additional Y or a Double Y like the image attached? If either of these options are no good, what would you suggest to make this work? Thanks for your feedback, time and knowledge sharing!
cz49vf is offline   Reply With Quote
Old 06-04-2011, 07:12 AM   #2
Super Moderator
Adding a new Y below the original should work fine--The double Ys some times 'back wash' into the drain across from it--avoid that possibility by adding a second single one.
Old 06-04-2011, 08:11 PM   #3
Many thanks for the response!
The Following User Says Thank You to cz49vf For This Useful Post:
oh'mike (06-04-2011)
Old 06-04-2011, 08:20 PM   #4
Super Moderator
With plumbing questions a picture really helps get a lot of accurate suggestions---
Your question is fine--this note is for the others watching this---Mike----
Old 06-05-2011, 11:04 AM   #5
i would set a tee-y right on top of the existing tee. typically bar sink counters are higher then vanity tops and bar sinks are usually not as deep so it should work out good. check your height before doing anything.
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Helping adding a light to an existing 3 way circuit. McSooner Electrical 4 12-03-2010 10:54 AM
Adding glass block to existing shower wall tns1 Remodeling 7 10-18-2010 10:15 AM
Adding Sprinkler Valve to Existing zone tilphan Landscaping & Lawn Care 3 03-29-2009 01:35 PM
adding window casing/moulding to existing windows Indy_Steve General Discussion 6 01-27-2008 03:58 PM
