Adding A Second Line To Existing Septic Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2012, 09:48 PM   #1
Adding a second line to existing septic line
I have a shop on my property. I want to add a bathroom and run a line and tap into existing line. Is that ok to do? When line T's in, it must go left to tank. Will it want to go right also? Does it matter where the second line goes into the existing line? Should it the in close to the tank? It would be easier to tie in at the location close to where existing line come out of the house.
Eddietan is offline   Reply With Quote
Old 05-09-2012, 10:07 PM   #2
I do not know what size septic tank & field you have so I cannot comment on that. You'd have to have an expert come and take a look.
If it does allow for the addition of a bathroom then you'd use a sani tee or sani Y, see below image, to tie it into the existing line.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Eddietan (05-10-2012)
Old 05-10-2012, 05:35 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Ayuh,... The only guarantee is,... It'll flow Downhill...
Bondo is online now   Reply With Quote
Old 05-10-2012, 09:27 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It's probably not legal to do so without having a septic tank inspection to make sure that the "additional load" will be properly handled by your size septic tank and drain field.
My personal opinion is that it's just a shop bathroom, you're not putting any extra waste or water down there that you wouldn't if you had to walk from the shop to your house to take a leak.
Journeyman Plumber
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Building raised Patio over Septic Line ChrisDIY Plumbing 5 07-08-2010 11:44 PM
Good approach for adding refrigerator line? Durt Ferguson Plumbing 5 06-15-2010 10:05 AM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
Adding a new water line to dishwasher and fridge? PMichaud Plumbing 18 01-05-2007 07:00 PM
