Adding A Second Bathroom To A Bungalow - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2010, 04:43 PM   #1
Adding a second bathroom to a bungalow
Hi there,
I am in the process of adding a second, 3 piece bathroom in my house. I am planning on running the drain through floor, parallel to the joists. I have enough room for proper slope. Here is my layout. Does this look suitable?
[IMG]file:///Users/sethrichards/Library/Caches/TemporaryItems/moz-screenshot.png[/IMG]
setherichards is offline   Reply With Quote
Old 11-15-2010, 09:51 PM   #2
assuming the branch on the 3x2 wye enters above the centerline of the 3", the only problem i see is the lav drain. the wet vent needs to be plumbed into the vent line, not the drain line. basically tie it into the vent for the toilet or tub above the drain for the fixture
the_man is offline   Reply With Quote
Old 11-16-2010, 06:30 AM   #3
Thanks. What do you mean by the centre line on the 3"?
Old 11-16-2010, 08:08 AM   #4
set the fitting so that nothing can flow back into the smaller pipe
Adding bathroom to adjacent room aminus21 Remodeling 2 04-11-2010 02:43 PM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 10:50 AM
plumbing/septic tank connection for adding a second bathroom mrbowma Plumbing 2 08-03-2009 04:51 AM
adding a bathroom browneyedsusie Plumbing 2 07-30-2009 11:18 PM
Adding a bathroom DDRowe Building & Construction 3 05-28-2005 06:51 AM
