Old 09-24-2010, 11:10 AM   #1
Adding second bathroom
Hi all...
The plan here is to tie the new bathroom drains into the existing drain, which then dumps into a septic tank and drain field.
So... the question is... can I tap into the existing Y cleanout under the house for the new drain (4")? Or would I have to dig up the existing pipe and put a 4" Y in?
Also, with regards to a vent pipe, can I tie the new vent pipes together (in the very tight attic) and run it horizontal (10 feet) into the existing (3"?) vent pipe, or does the new room need it's own vent?
More questions coming I'm sure.
Any replys welcome... tia... Al
Alvis is offline   Reply With Quote
Adding bathroom to adjacent room aminus21 Remodeling 2 04-11-2010 03:43 PM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 11:50 AM
Adding a Second Floor Bathroom in Iowa Iowa DIYer Plumbing 1 12-26-2009 03:38 AM
plumbing/septic tank connection for adding a second bathroom mrbowma Plumbing 2 08-03-2009 05:51 AM
adding a bathroom browneyedsusie Plumbing 2 07-31-2009 12:18 AM
