Adding Laundry Washing Machine Hose Through Concrete Wall, Equipment Rental - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2012, 02:37 PM   #1
Adding laundry washing machine hose through concrete wall, equipment rental
Hey Guys,
Where I can rent equipment to do some plumbing work for the laundry? I need to put a hose through a concrete wall.
I think I need a hammer drill, where can I rent this?
nynhpdiy is offline   Reply With Quote
Old 05-30-2012, 02:46 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Home Depot rents tools....and for the most part is a pretty good place to rent common tools as that.
But, if your doing just one hole....you might get by with just a concrete drill bit and your common drill. Sometimes on jobs like that, you spend more time chasing down the tools and returning them than the actual time the job takes.
A hammer drill will do the job in a couple of minutes....a masonry bit with your little drill might take 10-20 min....and that could be less time than the trip to HD.
Now, if you have a bunch of holes? Yea...rent the drill.
ddawg16 is online now   Reply With Quote
Old 05-30-2012, 05:05 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Hose through a concrete wall?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-30-2012, 05:07 PM   #4
JOATMON
ddawg16's Avatar
???Yea...good point....I was just thinking it wanted to run a pipe through there to go to the washer hose....
The Following User Says Thank You to ddawg16 For This Useful Post:
plummen (05-30-2012)
Old 05-30-2012, 07:11 PM   #5
Rewards Points: 13,960
The washing machine should be draining into your inside plumbing drains not out through a wall.
Ok what are you really up to?
Washing machine drain hose - how high can it pump? sheslostcontrol Plumbing 5 01-30-2012 08:39 AM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Washing Machine Dripping at Hose Connector..HELP! kswoot Plumbing 19 10-24-2008 08:12 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
