Adding Laundry Sink To Washer Drain - VENT? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2008, 11:13 PM   #1
Rewards Points: 12
Adding laundry sink to washer drain - VENT?
The builder on my new house got cheap on me and didn't install a laundry tub in the laundry room. I've checked under the house and found that they did run water for the sink but didn't bother to install valves in the wall or a drain stub. The water hookups are easy enough, but the drain has me wondering.
The cleanout for the washer drain pokes through the wall and tells me that there is a vertical drain/vent in the perfect spot for the laundry sink. It would be most simple to just tee into this line below the cleanout, but I'm not sure if it will be vented properly (and up to code).
Once I tear away the drywall, I'm guessing that I will find what you see in blue in my first picture.
My question is, can I just tee into the drain/vent stack with the sink, or do I need to add a vent loop. If I need a vent I'd like to do Option #1 because if I were to tee into the drain/vent stack, I wouldn't have room for a tee to go up to the new vent. (the red section is actually coming out of the wall towards you...)
I live in Oregon and don't know what the code says about venting. I'd like to know what I need to do before I get my permits and stuff.
Thanks in advance!
juengl4 is offline   Reply With Quote
Old 03-07-2008, 05:46 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
All of your options are non code compliant. By bringing the sink in above the washer drain you have created a "wet vent" at the washer.(a nono) Bring the sink draibn in at the same level as the washer drain and replace the tee fitting with a cross fititng with an internal baffle. No additional vent is neccessary. If you can't do that you must bring your sink drain back to the main line (under a slab I guess by your drawing). In that case you must extent the vent for the sink back to the vent line above the washer drain.
Old 03-07-2008, 08:46 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Being a Plumber in Oregon what rjniles said is correct, except the cross is not allowed, it is called a figure 5, and has no baffle. To use the figure a figure 5 fitting both flood level rims need to be at the same height. There is another way to do this without going under the floor, but no time to explain right now.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-07-2008, 09:01 AM   #4
Journeyman Plumber
You can di it this way.
Old 03-07-2008, 09:35 AM   #5
Rewards Points: 12
Thanks for the replies.
I just found this example:
http://www.terrylove.com/forums/show...hlight=laundry
Is this guy wrong? This looks like my "Option #1".
I'm going to pull off some drywall tomorrow so I guess I'll see if they prepped it for a sink. Based on the minimal amount of effort they put into other areas of the house, I really don't know what I'll find.
Thanks again!
Old 03-07-2008, 12:48 PM   #6
Journeyman Plumber
Looks good to me just make sure you use proper fittings, and before to tie into the existing vent make sure your 6" above the highest flood level rim.
Old 03-07-2008, 02:21 PM   #7
Rewards Points: 1,910
Ron, forgive my plumbing ignorance. I'm trying to figure out what is different between your option and the OPs second diagram titled Vent Option 1. Aren't they the same functionally? The washer drain and sink drain are reversed but the drain flow and vent flow look identical to me.
Old 03-07-2008, 05:45 PM   #8
Journeyman Plumber
Was just an optional way to plumb it in, there is more then one way to do this.
Old 03-09-2008, 12:46 AM   #9
Rewards Points: 12
A bit more interesting
Well, I cut out a few windows in the drywall and found that a dual vanity from upstairs is draining into the same 2" pipe as the washer...
Here is a picture/diagram of what I found:
Any thoughts on how to plumb in a laundry tub under these conditions? I would prefer to put the tub in between the studs as shown in the red oval, but I could change my plans and put them in the next cavity to the left if necessary.
Thanks for your help!
Old 03-09-2008, 01:19 AM   #10
Journeyman Plumber
Looks like you will need to replumb it under the house to do it to code.
Old 04-22-2009, 01:19 AM   #11
I stumbled upon this thread, looking to install a basement sink below the drain pipe too.
The Home Despot sells a flotec utility sink pump that claims to not require a vent or a trap. Model FPUS1860A. It hooks right up to the sink and has a 1" output line that requires a check valve.
Seems like everything else here would indicate that is very wrong.
Seems like this would be a nice easy option... If it is up to code.
archimedes is offline   Reply With Quote
Old 04-22-2009, 07:40 AM   #12
Wink
More than one way to skin a cat
Ron
The guy asked a simple question with an excellent presentation text and image, why did you have to add to it when all he needed was a simple yes or no answer. Did you have to have it your way to be right?????
SULTINI is offline   Reply With Quote
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 05:28 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
