Adding Laundry Sink - Can I "T" Into Washer Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2013, 11:05 AM   #1
Rewards Points: 33
Adding laundry sink - Can I "T" into washer drain?
I have an open-top drain pipe that runs down through the basement cement. Currently, my washing machine and water softener drain into the open top of the pipe. I want to add a laundry sink to the mix. Can I simply "T" into the drain about half way down or does something else need to be done to prevent the washing machine discharge from flowing back into the sink? Attached is a little diagram of what I am looking at.
Thanks for any advice you all can throw my way!
Koellert is offline   Reply With Quote
Old 03-04-2013, 11:19 AM   #2
DIY staff
Rewards Points: 7,174
Not going to work right----there is a P-trap below that washer stand pipe---t must be after the P-trap----
Koellert (03-07-2013)
Old 03-04-2013, 12:05 PM   #3
Rewards Points: 33
I was afraid of that. Anything that can be done short of busting out the cement? My 6" main drain is about 6 feet away... perhaps I could "T" into that to drain the washer.
Old 03-04-2013, 12:14 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 346
Remove the standpipe- convert it to the laundry sink. Then discharge the washer into the sink
Old 03-05-2013, 12:28 PM   #5
Rewards Points: 33
I wouldn't care if it siphoned out the p-trap under my laundry sink... but would it cause my sink to "back fill" with washer discharge?
Old 03-05-2013, 12:35 PM   #6
Plumber
Rewards Points: 346
Your sink will fill part way with water but assuming the drains are sized right and running clear- it shouldn't be an issue.
Can you upload a picture of your current set up? There might be a way to wet vent the sink. But it's hard to say without looking at your current configuration
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 03-07-2013, 10:47 AM   #7
Rewards Points: 33
Would this work? Even if it did siphon out the sink p-trap in this configuration, does it really matter? Doesn't the under-floor trap take care of sewer gas?
I'm not a plumber and I have learned a lot in trying to figure this out. Past help and additional ideas are greatly appreciated!
Thanks!
Old 03-08-2013, 07:28 AM   #8
DIY staff
There is a possibility that the washer will flood the sink if the drain ever slows down---that will be the only major draw back to that set up----and it is not code compliant---
Will it drain properly? Yes----
Koellert (03-08-2013)
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 03:37 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Relocating washer standpipe 71Whaler Plumbing 3 09-23-2011 11:23 AM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 08:11 PM
