Adding A Gas Fixture - Will The Metter Support ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2008, 10:50 AM   #1
Rewards Points: 1,062
Question
adding a gas fixture - will the metter support ?
i want to add a gas cook top in my basement. the existing fixtures are a 40 gal water heater and a boiler that heats water for the radiators for the whole house, about 2,600 sq ft including basement, about 6-7 radiators. do not have other metrics on the boiler.
i also do not have any metrics on the meter itself, although i recall seeing a number 75 on it, if that means anything.
i am quite skilled at pipe-fitting and have done gas work, rearranged and refit pipes. i do not have formal training that would have given me the knowledge about calcs and moderating meter size and fixture consumption but will eventually acquire it, for the time being i am picking y'all's brains. to make a long story short, i know the official advice is that this type of work falls outside of the DIY domain but i feel confident branching out a T and fitting a few nipples, as long as you tell me that the meter supply will be sufficient.
i will be home tomorrow evening, i can post some pics and perhaps look for some numbers on the meter/fixtures, if you think it would be useful.
thanks much,
- a -
Old 02-29-2008, 03:43 AM   #2
How far will the cook top be from the main gas line coming into the home?
redline is offline   Reply With Quote
Old 02-29-2008, 06:41 AM   #3
biggles's Avatar
you can tee off any main supply into a ON DEMAND item is just that...your furnace, hwh and exsisting stove the chances off all 3 running and the added item are not that common.for what the add on would use would not be a major drain on the others even during normal cycles.stoves/ranges are the least compared to a furnace or boiler
Old 02-29-2008, 08:09 AM   #4
the line is running right above it, so only maybe 4-5 ft below the tee.
thanks,
- a -
Old 02-29-2008, 10:22 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
You really need to know how many btus the meter will deliver and how much you're using. I went through the same process but I eventually found the specs of the meter online (275k btus). I had the gas company (keyspan) come out and give me a bigger one (425).
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-20-2011 12:58 AM
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 05:42 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
