-   -   adding a gas fixture - will the metter support ? (http://www.diychatroom.com/f7/adding-gas-fixture-will-metter-support-17782/)
amakarevic 02-28-2008 10:50 AM
i want to add a gas cook top in my basement. the existing fixtures are a 40 gal water heater and a boiler that heats water for the radiators for the whole house, about 2,600 sq ft including basement, about 6-7 radiators. do not have other metrics on the boiler.
i also do not have any metrics on the meter itself, although i recall seeing a number 75 on it, if that means anything.
i am quite skilled at pipe-fitting and have done gas work, rearranged and refit pipes. i do not have formal training that would have given me the knowledge about calcs and moderating meter size and fixture consumption but will eventually acquire it, for the time being i am picking y'all's brains. to make a long story short, i know the official advice is that this type of work falls outside of the DIY domain but i feel confident branching out a T and fitting a few nipples, as long as you tell me that the meter supply will be sufficient.
i will be home tomorrow evening, i can post some pics and perhaps look for some numbers on the meter/fixtures, if you think it would be useful.
thanks much,
- a -
redline 02-29-2008 03:43 AM
How far will the cook top be from the main gas line coming into the home?
biggles 02-29-2008 06:41 AM
you can tee off any main supply into a ON DEMAND item is just that...your furnace, hwh and exsisting stove the chances off all 3 running and the added item are not that common.for what the add on would use would not be a major drain on the others even during normal cycles.stoves/ranges are the least compared to a furnace or boiler
amakarevic 02-29-2008 08:09 AM
the line is running right above it, so only maybe 4-5 ft below the tee.
thanks,
- a -
Clutchcargo 02-29-2008 10:22 AM
63 Attachment(s)
You really need to know how many btus the meter will deliver and how much you're using. I went through the same process but I eventually found the specs of the meter online (275k btus). I had the gas company (keyspan) come out and give me a bigger one (425).
