Adding Fittings To Mid Run Of A Main Under Slab...???? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2011, 01:14 AM   #1
Adding fittings to mid run of a main under slab...????
I am adding in a lav and a shower drain about midway through a main line run. The slab is cut and the trench is dug. My question is, what is the correct way to put the main back after the fittings are installed. There is no room to slide that last fitting back onto the main. Am I supposed to use a rubber coupling to join the main back together ????
antalamo is offline   Reply With Quote
DWV remodel. Can I do this with my main? antalamo Plumbing 0 03-19-2011 10:29 AM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 03:20 PM
Adding a sub panel 250ft away from the main z-man99 Electrical 4 07-19-2009 02:56 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
