Old 03-04-2013, 12:14 PM   #16
adding a cleanout
Originally Posted by TheEplumber View Post
Simple answer is correct. Each trap needs a vent. They don't have to combine to a common vent stack. If you have seven fixtures- you could have seven vents through the roof- or 2 or 4 or 1....... As I said before, 6 plumbers-6 ways.
Ok, if you had this situation how would you personally vent the first and second story fixtures?
mikem201 is offline   Reply With Quote
Old 03-04-2013, 12:31 PM   #17
call me E
TheEplumber's Avatar
adding a cleanout
If the wet walls are stacked- probably one 4" vent
If not stacked- probably 2- 3" vents
If more then 1 plumbing wall per bathroom- each wall would vent separately unless I was told to minimize roof penetrations. (ladder work slows down production so I avoid combining vents in the attic)
Kitchen- most likely by itself.
UPC requires that the combined cross sectional area of the vents must at least equal the area of the building drain.
4" equals 12.56 Sq inches- The combined area of your vents must be at least that
Old 03-04-2013, 12:36 PM   #18
adding a cleanout
Ok, so when you say wet wall you mean a main waste vent stack behind the bathroom wall? If you were to run 2 separate stacks one main and one secondary, the secondary isn't just a vent stack right? It also serves as a drain then ties into the main stack or main drain line? Other than that if you dont want 2 separate vents then would you simple re-vent the fixtures from the 1st floor so they meet at a point above the 2nd floor?
Adding Laundry Sink notlawd1 Plumbing 2 01-02-2013 11:15 PM
New construction outside kitchen cleanout blocked off? markbair Plumbing 0 08-05-2012 11:26 PM
Sewer cleanout - which side of trap? KE2KB Plumbing 4 08-29-2011 09:56 AM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 10:56 PM
Re-using a drain cleanout mpt1123 Plumbing 0 01-19-2010 06:45 AM
