Adding Basement Bathroom. Rear Discharge Toilet Install Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2011, 11:19 AM   #1
Adding Basement Bathroom. Rear discharge toilet install question
I want to add a small bathroom in my basement.
My sewer stack exits through the side wall in my basement. About 2" off the ground. There was a cleanout that I unscrewed and tapped into to run my new plumbing. In the picture, the RED highlighted area is original plumbing and the BLUE is what my plumber added.
I'm installing a toilet on my basement and purchased a rear discharge toilet by Caroma..
http://www.caromausa.com/products/in...products72.php
Total distance from house drain to back of toilet is about 2 feet. I have the proper slope in that 2 foot section... About 1 inch over 2 feet.
Do you think I'll run into drainage issues from the toilet? Even with the largest "# 2's"?
I am thinking considering installing a backflow preventor somewhere but am not sure if I need one. My house is up on a hill so I'm not sure I have to worry about sewage backing in. I also don't know if there is a backflow preventer already installed. The house was built in 1999.
Adding Basement Bathroom.  Rear discharge toilet install question-basementremodel.jpg
paulyjsob is offline   Reply With Quote
Old 03-28-2011, 06:13 PM   #2
Rewards Points: 150
I don't know where you live but in the area that I'm familiar with doesn't allow those tees laying on their sides and the fernco type couplings, I can't see the rest of the pipe clearly
braindead is offline   Reply With Quote
Old 03-28-2011, 08:58 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
Same here. Also can't have tees on their back either(circled in red)
If that floor is above the sewer manhole you don't need a backwater valve. You don't have space with that layout anyways.
Whats the 2x11/2 tee for?
Old 03-29-2011, 06:18 AM   #4
Plumb or Die!
Looks kinda hackey...
plumber666 is offline   Reply With Quote
Old 03-29-2011, 02:03 PM   #5
Owner
LateralConcepts's Avatar
Are you sure it was a plumber???
I agree with the others.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 03-29-2011, 02:04 PM   #6
Owner
Is that main stack 6" ?
Lateral
(208) 818-8241
Old 03-29-2011, 03:55 PM   #7
Plumber
Rewards Points: 348
You need to have talk with your plumber. I see about 5 violations.
Did he pass inspection?
Old 08-16-2014, 08:06 AM   #8
backflush toliet
I'm pretty much going to do the same thing in my basement. The difference
being mine will be done the right way I hope. I want to do this the most
inexpensive way possible, and I know (diddly) about backflush toilets. Can I
get a little input on this.
thred60 is offline   Reply With Quote
Old 08-16-2014, 11:10 AM   #9
Rewards Points: 142
It's an old thread/post from 2011. If no results, start a new one with new titled.
jmon is offline   Reply With Quote
Old 08-16-2014, 02:59 PM   #10
Rewards Points: 1,684
You should start a new thread and pictures of what your doing help.
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 11:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Bathroom in Basement Question MudDuck Plumbing 5 09-14-2005 09:07 AM
