Adding An Additional Sink In Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2007, 09:56 PM   #1
Adding an additional sink in Bathroom
Hi all,
I am remodeling my 1970's bathroom and would like to add an additional sink. Venting may be an issue. The existing sink is very close to the main stack and doesn't have a vent loop (I think if it's real close to the main stack it doesn't need it?). So, for the second sink can I use a AAV (air admittance valve) on the second sink for additional venting?
Thanks,
BTW the bathroom is completely gutted to the studs. The studs are 2x3 studs for the interior walls not 2x4.
TKE402
tke402 is offline   Reply With Quote
Old 04-26-2007, 10:14 PM   #2
If what you are talking is a double vanity, all you need is a Y in your drain . Venting should be no problem.
brownie is offline   Reply With Quote
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 12:28 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 12:24 PM
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 06:47 AM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 10:10 PM
Adding a bathroom DDRowe Building & Construction 3 05-28-2005 07:51 AM
