Adding AAV ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2009, 10:01 AM   #1
adding AAV ?
I have 2 low flush toilets on different drain lines and vent stacks in different levels of the house both vented on 1 1/2" to attic where they join a 3" main vent stack. Although on separte lines these two both clog frequently.
I have a third toilet in line but vented direct on 3" stack which never causes problems.
After much investigation I can only assume there is a venting issue casing the frequent clogging. Since the 1 1/2" vents are burried and one is in line with a sink,one not can I add an AAV as well to increase ventilation for the two troublesome toilets?
Chemist1961 is offline   Reply With Quote
Old 01-24-2009, 01:48 PM   #2
are the two problem toilets on the same branch off of the stack, or are there to seperate tees in the stack.
zosoplumber is offline   Reply With Quote
Old 01-24-2009, 01:49 PM   #3
stupid question, i should have read more thoroughly. sorry
Old 01-24-2009, 01:51 PM   #4
You can add an AAV, but it seems fishy to me that venting would cause clogs so easily, are there any other fixture with problems
Old 01-24-2009, 02:50 PM   #5
Thats the issue. No other item on the upper 1 1/2" vent stack. It is in an outside wall and runs a total of about 12 ft before branching into the 3"
The lower level toilet vents backward from the basement through the sink drain 3' away from what I can tell, on a different stack in an inside wall and up to the attic as well where it intersects the 3".
Unless these two small diameter branches in the attic are freezing intermittently before they reach the 3" main I cannot figure out any other scenario for this frequent blockage. But I am sure I've had blockage summer and winter.
Old 01-24-2009, 02:52 PM   #6
And no , shower on upper level bath runs continually no buildup, sink is fine. Both vented on their own runs.
Old 01-25-2009, 11:11 PM   #7
1. Have the 2 toilets always been a problem or is this relatively new?
2. Are the 2 problem toilets the same model as the one that works fine?
3. Is the water level in each tank at the recommended water level mark?
kitsapjack is offline   Reply With Quote
adding lights mharwell01 Electrical 1 01-03-2009 03:59 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Adding new duct/Register CEbury HVAC 1 06-25-2008 10:51 AM
Adding additional landscaping steel Landscaping & Lawn Care 4 06-14-2008 01:25 AM
adding a second floor chubdo Building & Construction 11 04-16-2005 12:20 AM
