Adding 2nd Zone Baseboard Heat In Basement / PEX Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2010, 02:46 PM   #1
Rewards Points: 150
Adding 2nd Zone Baseboard heat in basement / PEX questions
Finishing my basement and i'd like to add a seperate zone from the rest of the house.
What is involved in doing so ? i'd probably be adding an additional 30 feet of baseboard heat approx.
Is it as easy as:
New T- Stat
2nd Circ Pump
Running plumbing ( IS PEX OK TO USE FOR RUNNING BASEBOARD HEAT SUPPLY/RETURNS ??)
Wiring it up
Any insight would be great.
alecmcmahon is offline   Reply With Quote
Old 11-17-2010, 06:50 PM   #2
if its a closed loop system,you must use heat pex (pex with oxygen barrier),
T stat
zone valve
no 2nd recirc. valve
how ever it is a little more complex than that, nothing a do it yourselfer cant do though.
I suggest to get a book and read up a bit
Ltnicks is offline   Reply With Quote
Remodeling Basement.. Have Heat vent/return air questions. CycloneBrian HVAC 7 02-06-2010 05:15 PM
baseboard heat cover SteveBman Remodeling 2 02-02-2010 07:00 AM
gurgling in baseboard heat in_the_basement HVAC 1 11-06-2009 10:41 PM
Alternative Basement Heat C_J_GO HVAC 8 04-01-2009 01:51 PM
Need to expand hot air heat to second floor and basement what are my options rossl56 HVAC 4 01-19-2009 04:53 AM
