-   -   Adding 2nd Zone Baseboard heat in basement / PEX questions (http://www.diychatroom.com/f7/adding-2nd-zone-baseboard-heat-basement-pex-questions-86981/)
alecmcmahon 11-17-2010 02:46 PM
Finishing my basement and i'd like to add a seperate zone from the rest of the house.
What is involved in doing so ? i'd probably be adding an additional 30 feet of baseboard heat approx.
Is it as easy as:
New T- Stat
2nd Circ Pump
Running plumbing ( IS PEX OK TO USE FOR RUNNING BASEBOARD HEAT SUPPLY/RETURNS ??)
Wiring it up
Any insight would be great.
Ltnicks 11-17-2010 06:50 PM
if its a closed loop system,you must use heat pex (pex with oxygen barrier),
T stat
zone valve
no 2nd recirc. valve
how ever it is a little more complex than that, nothing a do it yourselfer cant do though.
I suggest to get a book and read up a bit
