#1 |
adding 1/2 bath upstairs
Am installing a 1/2 bath upstairs, directly over the main bathroom. The current vent stack runs right up thru this room, can I plumb the new 1/2 bath toilet directly into this vent? If so, I assume it should connect to the main sewer line downstream from the main downstairs toilet? Will a 3" waste pipe suffice (I would like to bury it in a 2X4 wall)
#2 |
You can tie your vent pipe(s) into that stack only, and as you suggested, the 3" waste line will have to run down to the basement/crawlspace and tie in below the first floor fixtures. You can fit a 3" Pipe in a 2x4 wall but only if there are no fittings on the pipe; any fittings will make the stack wider than the wall cavity and force the sheetrock to bow outward.
Your vent(s) can be 1 1/2" (if each fixture is vented individually), or 2" (if it's a single "wet vent" for both fixtures. |
| Display Modes | |
| Chronic sewer gas odor emitting from upstairs bath | kadetklapp | Plumbing | 9 | 04-03-2012 06:05 PM |
| 1886 Eastlake - add upstairs bathroom or expand downstairs bath?? | TOTALN00B | Plumbing | 1 | 05-14-2011 10:54 PM |
| Adding Master Bath - layout ideas | bainer1290 | Building & Construction | 0 | 01-26-2011 10:31 AM |
| help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath | Heikks2002 | Plumbing | 3 | 01-15-2010 11:21 AM |
| Adding a 1/2 bath | mehaley | Plumbing | 1 | 07-20-2008 05:12 PM |
