Added Tile, Now Tub Faucet Doesnt Fit - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2012, 12:06 PM   #1
heinlein0311's Avatar
Rewards Points: 81
Added tile, now tub faucet doesnt fit
Hey, I had an alcove tub that was surrounded by drywall. I cut the 1/2" drywall out, replaced it with 1/2" cement board and tiled over the top with 4x4 tiles. My Problem is that the threads in my faucet are just a hair out of reach of the copper pipe/adapter coming out of the wall. I'm not real handy when it comes to soldering. Is there an adapter out there that will screw onto the existing adapter and then have threads on the other end that will screw into the faucet. I'll attach a picture of the existing adapter.
heinlein0311 is offline   Reply With Quote
Old 01-18-2012, 12:17 PM   #2
Rewards Points: 81
I apologize, when I say faucet I mean the spout.
Old 01-18-2012, 12:20 PM   #3
Rewards Points: 14,312
To choises, go behind the wall on the backside and try try figure out how to move the whole valve assembly out some more or learn how to solder.
Soldering is home repair 101 and is not that hard to learn how to do.
You may have to move the valve anyway so the handles will go back on.
Make sure both pipe and adapter are clean with sand paper wipe with a clean cloth, apply flux, heat until solder is sucked into the joint and stop. There is no need to keep adding more and have it all over the outside of the joint. It only holds inside.
Old 01-18-2012, 12:42 PM   #4
Rewards Points: 81
Can't get it from behind...it's a single handle and that is already mounted. Since the existing adapter is to short do I cut that one off and replace it with a longer one? The existing adapter is already soldered in place.
Old 01-18-2012, 12:57 PM   #5
DIY staff
Rewards Points: 7,174
Two choices---this is the easiest--solder the male end to a length of copper pipe--
When cool thread that into your spout----mark the pipe where the back of the spout is--
Unscrew it and set that aside---cut the tube coming out of the wall ---measure the length of the stub.
Deduct that amount from the line on your spout piece --cut there---
using s 'no stop ' coupling--solder the new piece to the wall stub---
Let it cool---pipe dope and tape the threads---install spout.
You won't like the second option---
Old 01-18-2012, 01:17 PM   #6
That tube will not be soldered inside the wall. There's going to be a male adapter on both ends, it's treaded into the valve assembly.
Old 01-18-2012, 01:34 PM   #7
DIY staff
It is possible that that is threaded into an eared flange behind the wall---but we don't know that---It could also be soldered into a 90*
Old 01-18-2012, 02:17 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Get yourself a tub spout thats held on with a set screw,then just cut the male adaptor off the end of the copper
plummen is offline   Reply With Quote
Old 01-18-2012, 03:58 PM   #9
Rewards Points: 81
Here's a pic showing the plumbing, looks to me that it's connected to a 90...I'm just going by the pic, unfortunately I'm not home right now. Would this have me doing anything different?
Old 01-18-2012, 04:06 PM   #10
DIY staff
Do as I suggested and you will be fine---that is soldered to a 90*
You need a male adapter---a no stop coupling and a short bit of copper pipe--flux--solder and a torch--tfe paste and teflon tape
Plummen gave you option number two----
Old 01-18-2012, 04:13 PM   #11
Rewards Points: 81
U gave really good directions, I appreciate that. Sounds simple enough. I'll have to do some mock up soldering til I get the hang of it. Thanks for the insight!
Old 01-18-2012, 04:33 PM   #12
DIY staff
Get the flux in the red tin---Oatey easy flow solder is a joy to work with---
Protect your new tub from splattered solder---don't over heat the pipe---when it's hot enough to melt the solder you are done----
Wrap a wet rag around the pipe by the tile for good luck---( Attractive tile job,by the way)--Mike--
Old 01-18-2012, 04:56 PM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 996
I would be very careful about soldering, too much heat and you could pop the seal on that rear joint in the wall, youíll never know its leaking until the damage has been made. I would go with plummenís advise, safer at this point.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-18-2012, 05:39 PM   #14
Rewards Points: 81
Pop the seal on the 90?
Old 01-18-2012, 05:56 PM   #15
Master Plumber
Javiles's Avatar
Rewards Points: 996
The elbow in the wall, thatís Not the correct way to pipe in spout feed, but what done is done.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
