Add Washing Machine Hookup Away From Plumbing Riser In High-rise Apartment - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2012, 11:35 AM   #1
Question
Add washing machine hookup away from plumbing riser in high-rise apartment
I'm in the market for a new apartment in NYC, where having a washer/dryer in your apartment is highly desirable. Some of the apartments listed are in buildings that allow washer/dryer hookups, but I would like to know if it is possible to add a washer hookup, when the location is not directly adjacent to the plumbing riser.
I have attached a floor plan of such a scenario, where I would have to route hot and cold water lines and a drain pipe around a bathroom.
If it's possible, any idea how much I might expect to pay, including opening up and patching up the walls?
These apartment buildings all tend to have concrete slab floors, so you can't go underneath.
And yes, there will be a problem with venting the dryer; a condenser dryer is the only viable choice and I know they don't work very well.
I'm posting this here, but I don't actually expect to do the work myself; I'll hire a licensed plumber, because the buildings typically require it for insurance purposes.
Thanks very much for your insight.
neoteric5 is offline   Reply With Quote
Old 09-24-2012, 10:35 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
I've done a few machine hook up over the years in high rise buildings, and to be honest it all boils down to how much are you willing to spend, it can get extremely complicated and expensive to do the work up to code. i would do some research with owners that have had the installations done, get with the buildings super and get a set of blue prints showing drain and water isometrics, then get with a reputable plumber preferably one who has done installations in the building in the past, and get an estimate, permits a must, for liability purposes,Water Damage to other units from? Good Luck.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
apartment , highrise , hookup , washer
Washing machine discharge hose Deck Plumbing 7 01-14-2012 08:15 PM
High efficiency washing machine odors dinosaur1 Appliances 0 05-27-2011 09:13 AM
External washing machine line. dproctor73 Plumbing 6 02-01-2011 12:16 PM
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 12:41 PM
High rise Plumbing question roach_779 Off Topic 8 01-17-2011 08:36 PM
