Add A Toilet Upstairs, Connect Plumbing To Current Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 04:25 PM   #1
Add a toilet upstairs, connect plumbing to current toilet?
Here is my problem. I have a flip house that upstairs has 2 bedrooms one of which is the master that shares bathrooms. It's terrible. My question is can I add a toilet and make a new bathroom, and tie in the new toilet to the existing toilets plumbing? Is that possible or against code? I have the ability to have the. Litterraky next to each other with just a wall to separate..
Thank you for your answers. I very much appreciate your time.
Jefeclay is offline   Reply With Quote
Old 01-21-2012, 04:45 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
I had a hard time understanding your post--With limitations, you can put more than one toilet on the stack but not on the existing toilet arm
Old 01-21-2012, 05:11 PM   #3
Sorry to be more clear. Upstairs has one bathroom that 2 bed rooms share. It's quite possibly the worst design ever. However, the actual sqft of the bathroom is HUGE. I'd like to take the huge bathroom and turn it into 2 bathrooms. The problem is adding a toilet.
Is there a way to have 2 toilets on the same plumbing line down? If so what is the best way to do this? The toilets can be right next to each other literally just divided by a wall.
Hope that is more clear?
Old 01-21-2012, 05:51 PM   #4
MarginallyQualified
Rewards Points: 2,464
Anything is possible.
All you have to do is draw it up on the back of a big enough check.
In that vein... draw it up.
The first toilet drains to a "stack".
How can you get to that stack to extend *another* pipe to the new spot?
What (if anything) is in the way?
I'm doing something like that this spring.
Stealing some space from the kitchen... rearranging the hall bath layout...
then adding a shower to the Master Bath (and a walk in closet).
2 toilets, 2 lavs, move the tub, add a shower (and the kitchen too)
Wanna come help?
leaking pipe under upstairs toilet mike49 Plumbing 1 06-23-2011 10:03 PM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 10:13 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
