Add Subfloor On Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 11:50 PM   #1
Rewards Points: 87
add subfloor on basement bathroom
I am thinking about adding insulation and subfloor on the basement bathroom floor like other rooms, which will rise the floor level about 2". Do I have to break concrete floor to redo the riser? Can I use the attached flange to avoid modifying riser?
add subfloor on basement bathroom-img_4222.jpg   add subfloor on basement bathroom-img_4226.jpg   add subfloor on basement bathroom-img_4228.jpg   add subfloor on basement bathroom-img_4230.jpg
diy001 is offline   Reply With Quote
Old 05-05-2012, 09:11 PM   #2
I recently used a product called dricore as a subfloor. Its only 7/8" thick and has a plastic bottom with channels built into it so water can sit underneath it. Air can also circulate. It is tongue and groover and easy to install.
sanec1 is offline   Reply With Quote
Old 05-05-2012, 10:09 PM   #3
Rewards Points: 630
yes it should work just make sure it is fastened good also another poster posted this link for a insulated basement floor here is link
http://www.ovrx.com/
i have also used dricore and it work well also here is link
http://www.dricore.com/en/contrac.aspx
both are available at home depot and lowes might need to be special order though
just so you have some options if you were looking
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
basement bathroom breiding200 Plumbing 4 03-22-2011 11:40 PM
basement bathroom breiding200 Plumbing 2 03-15-2011 04:05 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
Basement Bathroom - Sheetrock - Moisture Issues. mikeynpz Building & Construction 2 05-24-2009 11:08 AM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 05:27 PM
