Add Second Bathroom Sink - Tap Into Original - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2011, 09:56 AM   #1
Rewards Points: 310
add second bathroom sink - tap into original
Hey all - we have a doublewide vanity. The sink is on the right. There's plenty of room on the left for a second sink. I've owned homes with double sinks before - and each has their own hot/cold water supply and drain (presumably the drains of each meet up into one somewhere).
Anyway - can I drop in a few sink and add a faucet - but just tap into the original sink's water supply and drain?
And a related question - I recently redid the walls and mirror around this vanity. Only now am I thinking about the second sink. The vanity is that white shiny soapstone stuff. The original sink is molded into it. Is it possible to get a new drop-in sink (two, actually) and cut out the old molded-in sink and drop in the new one(s)?
Thanks!
denemante is offline   Reply With Quote
Old 03-22-2011, 12:21 AM   #2
Yes you can tap into the existing sink supply and run a second set of supplies to the new sink. Also I have heard it done, but never seen it, about cutting out the old molded sink then adding a second hole and using two new sinks. Sounds like a good idea if you really like your vanity top. By the time your fabricator (maybe yourself) cuts out the old sink and adds a second hole, the cost may be higher than just buying a new one with 2 holes already cut out. Good luck.
antalamo is offline   Reply With Quote
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 06:41 PM
Bathroom sink supply line leak afarr Plumbing 6 05-26-2010 05:59 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 09:14 PM
