Old 11-14-2011, 01:40 PM   #1
Question
Add new Drain Stack & Bathroom to second story.
Greetings,
We recently purchased a home built in 1923, only to discover there is a massive leak in the master bathroom shower. Repairing this leak will involve replacing the shower base (one leak) as well as replumbing the supply fixture (also leaking).
We had intended, later on down the road to convert a "sun room" attached to the master bedroom into the "new" master bathroom. As the present stack is too far away (and also old cast iron / lead) a new stack will be needed. The sun room sits atop a fully enclosed finished room downstairs with a generous crawlspace that leads into a basement.
I'm trying to figure out how feasible it is and what steps are involved to installing a new 4" ID drain stack. I understand we'll need to rip out the downstairs walls, ceiling, and upstairs floor to make this addition. What problems am I going to run into, is this possible, or is it a pipe dream?
The refinishing of walls and ceilings is not really a big deal to me as many of them are in the remodel process anyway. I just don't want to run into any "framing" issues getting the stack up to the second story, vented out the roof, etc.
Any advice / suggestions or information from someone who has done this in a home this old would be greatly appreciated.
tommywm is offline   Reply With Quote
Old 11-14-2011, 11:46 PM   #2
Persona Non Grata
VIPlumber's Avatar
If you could provide a current and future layout that would help us help you.
VIPlumber is online now   Reply With Quote
Tags
add bathroom, drain, new drain, remodel bathroom, stack
Tie stack to main drain rtoni Plumbing 3 04-21-2011 07:49 AM
Bathroom Sinks do not line up with drain pipe - what do I do? mark2741 Plumbing 7 04-15-2010 08:11 PM
Leaking bathroom drain. Concrete subfloor... Help crashtah Plumbing 2 05-27-2009 05:42 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 12:28 PM
