Add 2 Fixtures Existing Drain/Waste Pipe Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 11:18 AM   #1
I would like to add a kitchen sink (including dishwasher) and a laundry room sink to the existing 3 washer drain pictured. Can I use a 3 tee to add the kitchen sink and a 3 Tee to add the laundry room sink?
Also how many bends can my vent line have. For example this new kitchen sink vent line is following this path:
1. Straight up Vertically from the sink 9
2. Then a 90 bend and travels 6 horizontally
3. Then another 90 going up 18 (2 stories-2nd floor & attic) to roof
rickr86 is offline   Reply With Quote
Old 03-11-2013, 11:43 AM   #2
MarginallyQualified
Rewards Points: 2,464
and a laundry room sink to the existing 3” washer drain pictured.
1) That picture looks like a 2" pipe (from here)
2) The issue is "drain fixture units"
Figure out what you have/want then compare that to what YOUR county requires.a sample
Old 03-11-2013, 12:16 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
I agree that that looks like a 2" line(2.5" OD)
If its 3"- it should handle additional fixtures- depends on what else is on the line downstream. Also, since you have that trench open- consider replacing the cast iron with plastic. It will add life to your system for not much money.
Another point- you can't use tees in horizontal drainage lines-must be wyes. And don't forget some clean outs.
Proposed venting- your ok if I understood correctly
Old 03-12-2013, 08:13 AM   #4
It is a 2" line- can it still handle 2 additional fixture (2 sinks)?
I took that picture miday through construction so the trench is already covered with concrete. And yes after much more research I understand the reason for using a wyes and PVC underground. Thanks
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 01:48 PM
tapping into existing HVAC for basement denemante HVAC 3 10-27-2010 05:12 AM
Add 2 ceramic fixtures to existing switch diyneedshelp007 Electrical 4 03-01-2010 01:28 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 10:49 AM
