Old 08-26-2012, 05:04 PM   #1
Question
adapting an electric water heater for radiators
i was wondering if an electric water heater can be modified (with a pump of some sort) to heat water for radiators in a small apartment (800 sq ft). i have condoized a basement apartment that has radiator plumbing but will not have gas to cook water in a traditional boiler. so i was looking for an electric solution. i tried googling "electric boiler hydronic radiators" but all i got were forced heat products or regular hot water heaters.
thanks
Old 08-26-2012, 05:59 PM   #2
Thread killer
It can be done. Have you done a heat loss to size it? Is it a closed system? It could get expensive trying to heat with the electric HWT
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 08-26-2012, 06:14 PM   #3
no, i don't even know what the term means
Old 08-26-2012, 06:26 PM   #4
you think it'd be more efficient to use baseboard heaters? it is a typical small 1 BR apt., living room, kitchen, bath, little hallway, bedroom. i haven't hung DW yet so i could still run wire
Old 08-26-2012, 10:13 PM   #5
Thread killer
The heat loss is a calculation that will tell you how much heat your building will lose on the coldest day of the year to maintain its setpoint on the thermostat. i.e.; if your structure loses 60000 btu/hr on that day, then you need a device that supplies 60000 btu/hr of heat.
Not seeing your set up or the lay out and considering that HWT aren't rated for space heating, I'd say its probably a pretty safe bet that it would be much easier and better for you to install the electric baseboards.
Old 08-26-2012, 10:23 PM   #6
Who's going to be paying the light bill?
As I believe I've suggested before a simple very cheap to run and easy to install Mini Split heat pump would work.
Old 08-26-2012, 11:48 PM   #7
does that work in conjunction with a regular water heater?
i think i made up my mind to go with the baseboard solution
Old 08-27-2012, 01:13 AM   #8
biggles's Avatar
HWH won't do the outlet water temp a boiler does on a normal heating with baseboard 160F and up.the adding a B&G circ pump will work but the temp won't be there to make the stat at 70F.might just insulated the perimeter and floors and go with electric baseboard or as suggested slipt ductless HP..electric floor raidient might be an option?
Old 08-27-2012, 12:46 PM   #9
The heating power (think BTU) will be equal to the capabiity of one water heater element (about 4500 watts) Only one element in the water heater comes on at any given time.
Energy cost will be the same as for baseboard heaters of equivalent total wattage.
Cranking up the target temperature of the water (say to 160-190 degrees) will shorten the life of the water heater tank. Alternatively cranking up the temperature won't do anything because as the water circulates through the radiators it never gets near the target temperature.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-27-2012, 03:30 PM   #10
hey, please check out this new thread that i just created. thanks
need brand recommendation for baseboard heaters
Adding ground to electric water heater tadc Electrical 8 03-05-2012 09:14 PM
electric water heater shut off caryn keeper Plumbing 8 02-28-2012 07:39 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
