Acrylic Tub Installed W-out Frame. Serious? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2012, 11:58 PM   #16
Rewards Points: 616
here is of a reglazer ad but instead of putting hole in tub to reinforce go through apron or drill hole through floor from floor below to inject foam
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 08-03-2012, 12:16 AM   #17
Thanks. I will ask the manufacturer if the installation of a wood apron is necessary for support, and if leaving it out will void warranty. As for the foam, I looked to Home Depot for something that can be easily obtained here, and found "SikaFix PU". Wonder if you have heard of it or think it will work? Description: "Low-toxicity, two-component, 100% solid, polyurethane flexible foam. Use to stop water under a hydrostatic head and provide a resilient tough and flexible, closed cell polyurethane grout".
If the manufacturer okays the foam solution, I will ask the contractor to fill the tub with water first, before applying it. (I read that will prevent it from lifting the tub).
Morris C. is offline   Reply With Quote
Old 08-03-2012, 12:22 AM   #18
Actually, putting holes in the tub or through the floor below or anything that extreme won't be necessary here. There are two access holes in the drywall from which you can have (at least partial) access to the underside of the tub. One is in front of the drain area, the other on the side opposite the apron (tiled wall side).
Problem assembling bed frame kevind Carpentry 8 01-24-2011 12:59 PM
Raised tub - waterproofing solutions for wood frame against granite tile? lazzlazz Tiling, ceramics, marble 4 05-23-2010 02:15 PM
Building frame for painter's canvas Klawman Carpentry 3 01-19-2010 10:25 PM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 11:06 AM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 03:23 PM
