Acrylic Bathtub Water In Corners And Edges - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2013, 04:39 PM   #1
Rewards Points: 248
acrylic bathtub water in corners and edges
I am installing an acrylic bathtub. Built a cradle out of 2x4's. Perfectly level on all 4 sides. The bathtub fits in it and is perfectly level in both directions length and width. The problem is a small bit of water collects and lingers on the corners and edges. The corners and edges appear to be flat.
Should I be worried or is this par for the course for acrylic bathtubs? Any remedies for this type of situation?
jackwashere is offline   Reply With Quote
Old 10-30-2013, 05:01 PM   #2
Rewards Points: 12,808
Not sure what you mean by a cradle.
It should have been set in a bed of mortar so it was fully supported if there was not a built in foam base.
No install instructions right on the tub or on there web site?
Old 10-30-2013, 05:15 PM   #3
Rewards Points: 248
2x4's all around except for the faucet area. 2x4's attached to framing. The sides of the bathtub rest on the cradle.
The problem is not with the cradle. The cradle is just there to make sure the bathtub is level and offer solid support. The problem is that the acrylic tubs are manufactured with flat corners and edges. So water naturally collects and lingers in those places.
It should have been set in a bed of mortar ... if there was not a built in foam base.
I started another thread on this topic. The tub has a built in foam base but the floor (plywood) was ever so slightly off level. 1/8-1/4" over 4 feet. So on the faucet side of the tub the styrofoam base touches the plywood floor just right. On the far side of the tub the base is about 1/8-1/4" in the air. The other thread asked what to do to support the side in the air?
Old 10-30-2013, 06:47 PM   #4
Rewards Points: 6,652
Can you post a picture, with food coloring added to the water, to show what you mean that water is gathering in the corners of the tub. Also a picture with a four foot level on the backside and frontside, showing the slope of the tub, along with a picture with the level inside the tub bowl, showing the slope.
Old 10-30-2013, 07:03 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 348
I believe you are dealing with imperfection in the tub.
Only way I know to fix it is to put the the tub slightly out of level- back side up an 1/8". Not really proper though because you take the risk of having water run to the front apron
You don't want the tub rim solely supported by the ledger- nor do you want it in stress- it will crack
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 09:34 PM
Not Screwing Board Edges in Wall Corners? TomBrooklyn Drywall & Plaster 3 01-16-2010 11:53 PM
