Old 08-08-2012, 02:17 PM   #1
acoustic insulation for copper pipes
What is the best insulation to lower the noise of copper pipes? Neoprene? fiberglass? PE foam? mass loaded vinyl rools?
What about for "plastic" pipes?
I understand the value of each for thermal insulation, but not to know how they rate for sound insulation.
thanks
modusvivendi is offline   Reply With Quote
Old 08-08-2012, 11:30 PM   #2
I've never even heard of copper pipes making a noise unless there's air in the lines and it's making a water hammer.
Old 08-09-2012, 12:21 AM   #3
call me E
TheEplumber's Avatar
thanks
I would use preformed fiberglass pipe wrap. It comes in 1/2" or 1" wall thickness. I don't know the sound value but its what we use to pipes for condensate and heat loss.
If your pipes are contacting wood you might not be successful no matter which product you use
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Insulating pipes with foam insulation thinksincode Plumbing 6 12-08-2011 05:06 PM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
Insulation around water pipes secutanudu Building & Construction 3 10-06-2009 09:32 AM
