-   -   Acid neutralizer for household water system (http://www.diychatroom.com/f7/acid-neutralizer-household-water-system-147680/)
fwshipman 06-20-2012 11:34 AM
I am using calcite or soda ash to prevent the degradation of copper and brass pipe and fittings. Is there a risk of a negative effect on iron pipe, pressure tanks or water heater tanks?
Bob999 06-20-2012 02:09 PM
Properly used neither should adversly affect components of the plumbing system.
Calcite is "self regulating"--it won't lift pH to high. However soda ash, if injected at too high a rate, can increase pH above desirable levels.
