#1 |
Acetylene tank, how to know if full?
I would like to install a hose bibb on the outside of my house, I have a perfect place in which the cold water pipe is dead ended in the basement near the exterior wall.
I was at a yard sale a few weeks ago and bought a small fire extinguisher sized acetylene tank for $5. The gentlemen said that it was empty and I would have to exchange it for a full tank, but when I brought it home and opened the valve the gauge said "Full". So my question is if the tank is really full and the gentlemen was mistaken? Or if it is empty and the gauge isn't reading true? How would I know? Second question, I assume I should take the gauge and hose all off before bringing it somewhere (plumbing supply house?) to be exchanged, correct? |
#2 |
Household Handyman
I cannot relate the two issues here: The cold water piping and the acetylene tank.
You could take the tank, minus anything that attaches to it, to a local welding supply house to have it weighed. They know the full/empty weight of most cylinders. Catch them on a good day and they just might do it for free. NOW: There are two local welding supply centers in my town. NEITHER one will swap, nor fill, those sized tanks at all. The both will send someone to the local Tractor Supply store to do an exchange. David |
#3 |
Acetylene tank, how to know if full? |
#4 |
#5 |
I was going to sweat the pipes with solder. I was told that mapp isn't optimal for 3/4" pipe so I picked up the acetylene tank for cheap to do the work. No good?
#6 |
call me E
acetylene is great for soldering as well as brazing. As a home owner, its more then you need. I've used it for 1/2 - 4" copper but you need an asortment of tips.
#7 | |
Master General ReEngineer
Acetylene tank, how to know if full?Quote:
mapp is more than enough for 3/4",... 'ell, propane will Easily do 3/4"... |
#8 |
So what do you suggest, not filling the acetylene tank- buy a mapp torch instead?
#9 | |
call me E
BTW- hows your soldering skills? |
#10 |
Did the bottle have a gage regulator on it?? If it did and you opened it and it read full is there a little regulator on it that you have to turn to get the gas to come out.
#11 |
Just call me Andrew
Get a Mapp torch...I did a project recently and used it to solder a bunch of 1" connections.
Andrew |
#12 |
You don't need mapp gas just one of those little solder sets will do it.
#13 |
Till now I thought acetylene needed an oxygen tank to get real hot. Just for education sake, (I won't be buying one), does the flame from acetylene alone burn hotter than mapp?
#14 |
Yes, there is the square shank that needs to be turned the open the tank, then a regulator and gauge. The gauge said full. Does that mean that the tank is full? If so, I'll save a lot of money by just using it to solder what I need. To go out now and buy all the MAPP equipment will cost quite a bit for a couple of joints.
#15 |
gravity always wins
Acetylene mixed with pure oxygen will burn at 5000 degrees plus. Enough to melt steel. An acetylene torch that uses atmopheric air as an oxydizer (like a plumber's Turbo Torch) will burn cooler, but still plenty hot enough to solder or braze. MAPP gas burns approximately equal in temperature to acetylene, but is contained and transported as a liquid, rather than a compressed gas like acetylene. If you have a good bottle and regulator and a decent torch, then use it. Just be careful. It doesn't take long to overheat a copper fitting with an acetylene torch.
| Display Modes | |
| Liquid Septic Tank Full. How do I troubleshoot? | chains350 | Plumbing | 6 | 11-08-2010 09:59 AM |
| Pressure relief leaking and expansion tank full | themow | HVAC | 1 | 11-25-2009 05:49 PM |
| Toilet | jpark | Plumbing | 18 | 01-05-2009 08:12 AM |
| Nightmare water tank job | Marvin Gardens | Plumbing | 6 | 11-04-2008 12:09 PM |
| Upstairs toilet pipe noise | bliss | Plumbing | 8 | 01-10-2008 08:55 AM |
