ACE Hardware- Thin Type L Copper Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2012, 04:10 PM   #1
Rewards Points: 33
Question
ACE Hardware- thin type L copper pipes?
I normally buy copper from Home Depot, but today I ran into ACE (which is closer) to pick up 20ft of type L pipe for a bathroom remodel I'm working on. When I got home and made my first cut I noticed that it went a lot quicker than normal. Sure enough, upon inspection the ACE hardware copper pipe has substantially thinner walls than the Home Depot type L pipe.
Should I be concerned about this? I know the difference between type M and type L is just wall thickness, so I haven't installed anything yet.
Am I being overly cautious or has anyone else had experience with these pipes from ACE Hardware?
MikeDobbs is offline   Reply With Quote
Old 05-27-2012, 04:14 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Are you sure it has blue lettering on it?
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
jaydevries (05-27-2012), oh'mike (05-27-2012), plummen (05-27-2012)
Old 05-27-2012, 09:03 PM   #3
Rewards Points: 33
The pipe from ACE hardware has neither Blue (Type L) nor Red (Type M) lettering on it. However, the lettering that is on it does say Type L
Old 05-27-2012, 09:09 PM   #4
Rewards Points: 14,304
It's medium walled tubing and will work fine.
http://www.acehardware.com/info/inde...goryId=1280921
Old 05-27-2012, 09:23 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Around here we normally use type L for commercial jobs and M for residential work.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-27-2012, 09:38 PM   #6
DIY staff
Rewards Points: 7,174
Lucky you---Type L for all residential in this area--
Old 05-27-2012, 09:58 PM   #7
plummen's Avatar
If local 16 had it their way we'd still be using cast iron with oakum/lead joints and galvanized steel water lines in residential work,sounds kind of like chicago!
Anyway we get away with type M for residential but we can also use cpvc,but no pex because they say the chlorine in water hurts the pipes but they can use it in bellevue right next door who uses same water supplier!
Old 05-28-2012, 01:37 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
Half my house is done with L (when the original owners repiped)...most of the stuff I did using M.
The advice I got from a plumber...use L if the pipe is going to be exposed to any kind of abuse....as in outside or at the end of a hand valve. M is fine if it's up inside a wall where it is protected.
M also sweats a lot quicker.
Mike....if you payed for L but you think you have M...take it back. If you have some spare L with the blue stripe on it...you might want to take it as well to show them that your being cheated.
Old 05-28-2012, 06:34 AM   #9
Rewards Points: 1,216
TYPES OF PIPE
Copper K Thickest
Copper L Medium
Copper M Thinest Residential water use
AC&R Copper Air Conditioning Refrigeration. Specially dried with nitrogen and plugged.
COLDIRON is offline   Reply With Quote
Tags
copper pipe , plumbing
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 12:30 AM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 08:39 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
