Access Panel Or Door For Shower Plumbing Any Pics? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2008, 07:14 PM   #1
Rewards Points: 150
Access Panel or Door for Shower Plumbing Any pics?
I am in the process of redoing all of my plumbing. I think I would like to make an access panel behind the shower. There is a hallway right behind the shower and drywall there. If I cut a hole in the drywall I can access the plumbing easily. I wanted to cut out the drywall in that section and make an access door or panel and wanted to get some ideas. Does anyone have pics of doors or their own panels? Thanks.
twilightcall is offline   Reply With Quote
Old 06-11-2008, 07:21 PM   #2
Depending on the height you can use drywall anchors and mount a picture or mirror over the hole and no one will
know.I have used this before. You can not hide it any other way. You can frame around the outside and make a nice square opening and paint it the same as the wall and will look good.
BillyD is offline   Reply With Quote
Old 06-11-2008, 07:42 PM   #3
Most home centers carry premade access panels that can be painted to match the wall:
http://contractorservices.homedepot....1-5f7e78f7116d
jerryh3 is offline   Reply With Quote
Old 06-11-2008, 08:10 PM   #4
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
twilight,
There are several types of access panels out there but the reality is that they all look like..., well, access panels. If you are replacing the valve and/ or drain assembly (and you do a good job) you won't need to access it for many years. Why not just leave it opened for long enough that your are confident your plumbing is good and then just cover it back up? As long as you go ahead and get a good, name brand valve now, if you decide to change finishes or styles later you should be OK.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 12-22-2009, 05:53 AM   #5
295yards's Avatar
I am going through this right now and a poster in my thread gave me this link, which I hope helps you as well.
You can go with what I am doing ( the one with the drywall beads so the opening is mudded in ) and all you'll virtuall see is a small gap of a 16th of an inch.
Just get your lines straight and I think you'll be happy!
http://www.google.com/products/catal...749&sa=title#p
295yards is offline   Reply With Quote
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Should I replace all of the plumbing? Pics enclosed? twilightcall Plumbing 15 01-23-2008 08:50 AM
Plumbing distance from Circut Panel Dragon Electrical 7 04-13-2007 06:52 PM
access panels for plumbing Michaela521 Plumbing 3 04-10-2006 04:26 PM
