Access Panel Behind Shower Required? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2010, 12:40 PM   #1
Access panel behind shower required?
I am in the process of re-doing my bathrooms in the house, and with my current re-design for the upstairs bathroom, the shower will be on an outside wall. Meaning, supply lines, mixing valve and showerhead will be all located on an outside wall on the second floor. Am I required to put an access panel behind the shower mixing valve or not?
If it matters, I am located in Houston, TX.
Ovidiu is offline   Reply With Quote
Old 12-25-2010, 12:48 PM   #2
Homerepairguy's Avatar
Rewards Points: 990
Don't know if an access panel is required in your area. My suggestion is that if it's not required, take pictures of your piping before you enclose them. Supplement the pictures with accurate measurements, especially the distance of pipes from the exterior wall. Then, if you ever need to access the plumbing, you can cut a hole for an access panel without fear.
HRG
Homerepairguy is offline   Reply With Quote
Old 12-25-2010, 01:45 PM   #3
Picky Plumber
Check with local codes but around here it's not required. It likely doesn't get very cold there so you shouldn't have to worry with the pipes freezing. Make sure that insulation is between piping and exterior wall.
Plumber26 is offline   Reply With Quote
Old 12-25-2010, 07:34 PM   #4
Very good suggestions, thanks! I will definitely take pictures and accurate measurements should I need to do anything later. I am using pex for all the piping and will put it on the inside of the insulation.
I checked Houston City codes and saw no mention of a requirement for an access panel.
Old 12-26-2010, 07:53 AM   #5
Rewards Points: 1,418
Do not put insulation between any pipe and the inside wall, even if the total R value at that spot is less than recommended. Batt insulation may be squeezed between the pipe and the outside wall, or rigid or foam insulation may have a V shaped trench cut out of it as wide at the inside wall as the distance the pipe is from the inside wall.
Old 12-26-2010, 09:05 AM   #6
You don't need an access panel. Most if the time when we install in an outside wall the pipes are protected either with high density foam or spray foam. DO NOT CRUSH OR FORCE BATT FIBERGLASS, IT LOSES ALL R VALUE.
Work4living is offline   Reply With Quote
Old 12-26-2010, 10:46 AM   #7
Most areas do not require an access panel. Do yourself a favor though, and install shut-off valves for the water lines somewhere accessable.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-26-2010, 03:06 PM   #8
Rewards Points: 990
Be very careful about anything that can come in contact with your pex tubing. Especially, certain types of foam can deteriorate pex tubing. If in doubt, there is pex approved insulation that goes around the tubing which can isolate it from non-approved stuff.
HRG
Old 12-26-2010, 03:14 PM   #9
It does not lose "ALL" Rvalue
The Rvalue lost depends upon the insulation & compression
Access Panel or Door for Shower Plumbing Any pics? twilightcall Plumbing 4 12-22-2009 06:53 AM
Jacuzzi tub access panel 295yards Building & Construction 10 12-22-2009 06:46 AM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
shock in shower tbwoods Electrical 64 07-23-2009 12:26 PM
Accessing evap coil - creating a reusable access panel bifjamod HVAC 1 07-07-2009 01:14 PM
